Enabling dynamic dimensions for a layer and restarting geoserver results in the following error during startup:
2016-08-05 09:39:27,060 ERROR [config.util] - Class org.geoserver.wms.dimension.DefaultValueConfiguration is not whitelisted for XML parsing.
This is done to prevent Remote Code Execution attacks, but it might be
you need this class to be authorized for GeoServer to actually work
If you are a user, you can set a variable named GEOSERVER_XSTREAM_WHITELIST
with a semicolon separated list of fully qualified names, or patterns
to match several classes.The variable can be set as a system variable
a enviromment variable, or a servlet context variable, just like
GEOSERVER_DATA_DIR.
For example, in order to authorize the org.geoserver.Foo class,
plus any class in the org.geoserver.custom package, one could set
a system variable:
-DGEOSERVER_XSTREAM_WHITELIST=org.geoserver.Foo;org.geoserver.custom.**
If instead you are a developer, you can call allowTypes/allowTypeHierarchy against
the XStream used for serialization by rolling a custom
XStreamPersisterInitializer or customizing your XStreamServiceLoader.
2016-08-05 09:39:27,061 WARN [org.geoserver] - Failed to load coverage 'bmng'
com.thoughtworks.xstream.converters.ConversionException: Unauthorized class found, see logs for more details on how to handle it: org.geoserver.wms.dimension.DefaultValueConfiguration : Unauthorized class found, see logs for more details on how to handle it: org.geoserver.wms.dimension.DefaultValueConfiguration
---- Debugging information ----
message : Unauthorized class found, see logs for more details on how to handle it: org.geoserver.wms.dimension.DefaultValueConfiguration
cause-exception : org.geoserver.config.util.SecureXStream$ForbiddenClassExceptionEx
cause-message : Unauthorized class found, see logs for more details on how to handle it: org.geoserver.wms.dimension.DefaultValueConfiguration
class : java.util.ArrayList
required-type : java.util.ArrayList
converter-type : org.geoserver.config.util.XStreamPersister$ProxyCollectionConverter
line number : 71
class[1] : org.geoserver.wms.dimension.DefaultValueConfigurations
converter-type[1] : com.thoughtworks.xstream.converters.reflection.ReflectionConverter
class[2] : org.geoserver.catalog.MetadataMap
converter-type[2] : org.geoserver.config.util.XStreamPersister$MetadataMapConverter
class[3] : org.geoserver.catalog.impl.CoverageInfoImpl
converter-type[3] : org.geoserver.config.util.XStreamPersister$CoverageInfoConverter
version : 2.9.0
at com.thoughtworks.xstream.core.TreeUnmarshaller.convert(TreeUnmarshaller.java:79)
at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnmarshaller.java:66)
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.unmarshallField(AbstractReflectionConverter.java:474)
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.doUnmarshal(AbstractReflectionConverter.java:406)
at com.thoughtworks.xstream.converters.reflection.AbstractReflectionConverter.unmarshal(AbstractReflectionConverter.java:257)
at com.thoughtworks.xstream.core.TreeUnmarshaller.convert(TreeUnmarshaller.java:72)
at com.thoughtworks.xstream.core.TreeUnmarshaller.convertAnother(TreeUnmarshaller.java:50)
at org.geoserver.config.util.XStreamPersister$BreifMapConverter.populateMap(XStreamPersister.java:824)
at com.thoughtworks.xstream.converters.collections.MapConverter.unmarshal(MapConverter.java:87)
at org.geoserver.config.util.XStreamPersister$MetadataMapConverter.unmarshal(XStreamPersister.java:948)
at org.geoserver.config.util.XStreamPersister$ResourceInfoConverter.doUnmarshal(XStreamPersister.java:1729)
at com.thoughtworks.xstream.core.TreeUnmarshaller.start(TreeUnmarshaller.java:134)
at com.thoughtworks.xstream.core.AbstractTreeMarshallingStrategy.unmarshal(AbstractTreeMarshallingStrategy.java:32)
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:1185)
at com.thoughtworks.xstream.XStream.unmarshal(XStream.java:1169)
at com.thoughtworks.xstream.XStream.fromXML(XStream.java:1049)
at org.geoserver.config.util.XStreamPersister.load(XStreamPersister.java:597)
at org.geoserver.config.GeoServerLoader.depersist(GeoServerLoader.java:764)
at org.geoserver.config.GeoServerLoader.readCatalog(GeoServerLoader.java:423)
at org.geoserver.config.GeoServerLoader.readCatalog(GeoServerLoader.java:223)
at org.geoserver.config.DefaultGeoServerLoader.loadCatalog(DefaultGeoServerLoader.java:36)
at org.geoserver.config.ReadOnlyGeoServerLoader.loadCatalog(ReadOnlyGeoServerLoader.java:54)
at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:109)
at org.geoserver.config.GeoServerLoaderProxy.postProcessBeforeInitialization(GeoServerLoaderProxy.java:59)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:408)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1570)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:545)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:482)
at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:306)
at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:302)
at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:351)
at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:108)
at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:648)
at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:140)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1143)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:1046)
at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:510)
at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:296)
at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:772)
at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:839)
at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:538)
at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:444)
at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:326)
at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:107)
at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:23)
at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4842)
at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5303)
at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:147)
at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:725)
at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:701)
at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:717)
at org.apache.catalina.startup.HostConfig.deployDescriptor(HostConfig.java:587)
at org.apache.catalina.startup.HostConfig$DeployDescriptor.run(HostConfig.java:1798)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
at java.util.concurrent.FutureTask.run(FutureTask.java:266)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
at java.lang.Thread.run(Thread.java:745)
Caused by: org.geoserver.config.util.SecureXStream$ForbiddenClassExceptionEx: Unauthorized class found, see logs for more details on how to handle it: org.geoserver.wms.dimension.DefaultValueConfiguration
at org.geoserver.config.util.SecureXStream$DetailedSecurityExceptionWrapper.realClass(SecureXStream.java:175)
at com.thoughtworks.xstream.mapper.MapperWrapper.realClass(MapperWrapper.java:30)
at com.thoughtworks.xstream.mapper.CachingMapper.realClass(CachingMapper.java:47)
at com.thoughtworks.xstream.core.util.HierarchicalStreams.readClassType(HierarchicalStreams.java:29)
at com.thoughtworks.xstream.converters.collections.AbstractCollectionConverter.readItem(AbstractCollectionConverter.java:70)
at com.thoughtworks.xstream.converters.collections.CollectionConverter.addCurrentElementToCollection(CollectionConverter.java:98)
at com.thoughtworks.xstream.converters.collections.CollectionConverter.populateCollection(CollectionConverter.java:91)
at com.thoughtworks.xstream.converters.collections.CollectionConverter.populateCollection(CollectionConverter.java:85)
at com.thoughtworks.xstream.converters.collections.CollectionConverter.unmarshal(CollectionConverter.java:80)
... 110 more
Caused by: com.thoughtworks.xstream.security.ForbiddenClassException: org.geoserver.wms.dimension.DefaultValueConfiguration
at com.thoughtworks.xstream.security.NoTypePermission.allows(NoTypePermission.java:26)
at com.thoughtworks.xstream.mapper.SecurityMapper.realClass(SecurityMapper.java:74)
at org.geoserver.config.util.SecureXStream$DetailedSecurityExceptionWrapper.realClass(SecureXStream.java:150)
... 119 more
This can be fixed by adding the following classes in DynamicDefaultXStreamInitializer.java:27:
xs.allowTypeHierarchy(org.geoserver.wms.dimension.DefaultValueConfiguration.class);
xs.allowTypeHierarchy(org.geoserver.wms.dimension.DefaultValueConfigurations.class);
I am trying to prepare a pull request.
