[Geoserver-devel] [JIRA] (GEOS-7683) Unable to remove rest-access rule through rest command
Eibl created an issue
GeoServer / BugGEOS-7683
Issue Type:
BugBug
Affects Versions:
2.9.1
Assignee:
Unassigned
Components:
REST, Security
Created:
16/Aug/16 2:23 PM
Priority:
MediumMedium
Reporter:
Eibl
It is not possible to remove a rest access rule with:
http://192.168.0.2/geoserver/rest/security/acl/rest/%2Frest%2Fworkspaces%2Ffoo%2F**;GET,POST,DELETE,PUT which was created with: http://192.168.0.2/geoserver/rest/security/acl/rest.xml and data: “<rules><rule resource=”/rest/workspaces/foo/**:GET,POST,DELETE,PUT">foo</rule></rules>"
The rule is stored in rest.properties as: /rest/workspaces/foo/**;GET,POST,DELETE,PUT=foo
There is no entry about failure, exception nor success in the geoservers log file
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.245.1#100009-sha1:a18e8d3)
Atlassian logo
