[Geoserver-devel] [JIRA] (GEOS-7720) Importer extension REST module tests contain an applicationContext.xml
Nuno Oliveira created an issue
GeoServer / BugGEOS-7720
Issue Type:
BugBug
Assignee:
Nuno Oliveira
Components:
Importer
Created:
06/Sep/16 7:56 PM
Priority:
MediumMedium
Reporter:
Nuno Oliveira
Tests Spring application contexts declared as applicationContext.xml may be included in the normal classpath when starting GeoServer from some IDEs.
To avoid this situation tests Spring context files should not be named applicationContext.xml and should be manually included:
    @Override
    protected void setUpSpring(List<String> springContextLocations) {
        super.setUpSpring(springContextLocations);
        springContextLocations.add("classpath:TestContext.xml");
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.305.0#100011-sha1:1dc2d9a)
Atlassian logo
