[Geoserver-devel] [JIRA] (GEOS-7732) CSS: stroke-offset does not accept expressions
Go Sato created an issue
GeoServer / BugGEOS-7732
Issue Type:
BugBug
Affects Versions:
2.9.1
Assignee:
Unassigned
Components:
CSS
Created:
08/Sep/16 2:56 PM
Environment:
Amazon Linux (Linux 4.4.19-29.55.amzn1.x86_64 x86_64)
Oracle JRE 1.8.0_74
Tomcat 7.0.70
Priority:
MediumMedium
Reporter:
Go Sato
Hello,
I was trying to create a style visualising traffic flows as stroke width on the road network like the attached image.
I was trying to submit the following to CSS Styling extension (GeoServer 2.9.1)
Unable to find source-code formatter for language: css. Available languages are: actionscript, html, java, javascript, none, sql, xhtml, xml
  stroke: #27b700;
  stroke-linecap: butt;
  stroke-linejoin: bevel;
  stroke-width : [ max(0.5, min(58.27, traffic_flow * 58.27 / 20000)) ];
  stroke-offset: [ -0.5 * max(0.5, min(58.27, traffic_flow * 58.27 / 20000)) - 1 ];
The CSS was accepted without validation errors but the generated SLD turned out to be the following
<sld:StyledLayerDescriptor xmlns="http://www.opengis.net/sld" xmlns:sld="http://www.opengis.net/sld" xmlns:gml="http://www.opengis.net/gml" xmlns:ogc="http://www.opengis.net/ogc" version="1.0.0">
  <sld:NamedLayer>
    <sld:Name>Default Styler</sld:Name>
    <sld:UserStyle>
      <sld:FeatureTypeStyle>
        <sld:Rule>
          <sld:LineSymbolizer>
            <sld:Stroke>
              <sld:CssParameter name="stroke">#27b700</sld:CssParameter>
              <sld:CssParameter name="stroke-linejoin">bevel</sld:CssParameter>
              <sld:CssParameter name="stroke-width">
                <ogc:Function name="max">
                  <ogc:Literal>0.5</ogc:Literal>
                  <ogc:Function name="min">
                    <ogc:Literal>58.27</ogc:Literal>
                    <ogc:Div>
                      <ogc:Mul>
                        <ogc:PropertyName>traffic_flow</ogc:PropertyName>
                      </ogc:Mul>
                      <ogc:Literal>20000</ogc:Literal>
                    </ogc:Div>
                  </ogc:Function>
                </ogc:Function>
              </sld:CssParameter>
            </sld:Stroke>
            <sld:PerpendicularOffset>((-0.5*max([0.5], [min([58.27], [((traffic_flow*58.27)/20000)])]))-1)</sld:PerpendicularOffset>
          </sld:LineSymbolizer>
        </sld:Rule>
        <sld:VendorOption name="ruleEvaluation">first</sld:VendorOption>
      </sld:FeatureTypeStyle>
    </sld:UserStyle>
  </sld:NamedLayer>
</sld:StyledLayerDescriptor>
You will see that the interpretor just put the stroke-offset to PerpendicularOffset without any tranlation, not even wrapped in ogc:Literal tag. Consequently, GeoSever throws an error when this SLD is applied.
The correct SLD should be like this. This has worked without errors as GeoServer allows expressions for PerpendicularOffsett.
  <sld:NamedLayer>
    <sld:UserStyle>
        <sld:Rule>
            <sld:Stroke>
                    <ogc:Div>
                      <ogc:Mul>
                      </ogc:Mul>
                    </ogc:Div>
                  </ogc:Function>
                </ogc:Function>
              </sld:CssParameter>
            </sld:Stroke>
              <ogc:Add>
                <ogc:Mul>
                  <ogc:Literal>-0.5</ogc:Literal>
                      <ogc:Div>
                        <ogc:Mul>
                        </ogc:Mul>
                      </ogc:Div>
                    </ogc:Function>
                  </ogc:Function>
                </ogc:Mul>
                <ogc:Literal>-1</ogc:Literal>
              </ogc:Add>
        </sld:Rule>
    </sld:UserStyle>
  </sld:NamedLayer>
I can live with the old SLD in the meantime but I think it is worth to enable users to use expressions for stroke-offset.
I have also tried this CSS in the refined new style editor but things were the same.
Many thanks,
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.319.1#100012-sha1:913341f)
Atlassian logo
