[Geoserver-devel] [JIRA] (GEOS-7735) vector to raster render transform does not use bbox in query filter
Rich Fecher created an issue
GeoServer / BugGEOS-7735
Issue Type:
BugBug
Affects Versions:
2.9.1
Assignee:
Unassigned
Components:
WMS
Created:
09/Sep/16 5:34 PM
Priority:
MediumMedium
Reporter:
Rich Fecher
The default behavior of the vector to raster transform is to use “direct raster rendering.” Through this path, the feature source will never use the bbox from the WMS request which can be very expensive. This can be disabled globally through the java property org.geoserver.render.raster.direct.disable (ie. run geoserver with VM argument “-Dorg.geoserver.render.raster.direct.disable=true”) but this is less desirable than changing the default behavior.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.319.1#100012-sha1:913341f)
Atlassian logo
