[Geoserver-devel] [JIRA] (GEOS-7749) ArrayIndexOutOfBounds exc on CoverageViewReader
Thanassis Mantes created an issue
GeoServer / BugGEOS-7749
Issue Type:
BugBug
Assignee:
Unassigned
Components:
Main
Created:
20/Sep/16 8:05 AM
Priority:
MediumMedium
Reporter:
Thanassis Mantes
When a CoverageView is created with more bands than those of any of the composing coverages, an ArrayIndexOutOfBounds exception occurs on CoverageViewReader at the procedure of the resulting coverage dimension wrapping. This occurs because dimension wrapping is done during reading of the composing coverages, and should take place only after the resulting coverage is created.
This issue was addressed partially during the latest inprovements on CoverageViewReader, but a use case with a specific dataset showed that there were some cases not fully covered.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.319.1#100012-sha1:913341f)
Atlassian logo
