Torben Barsballe created an issue |
Issue Type: |
Assignee: |
Unassigned |
Created: |
21/Sep/16 12:20 AM |
Priority: |
Reporter: |
If you try and rename one of the default geoserver styles (point, polygon, line etc.) the style will get recreated when you restart geoserver. This will result in having two differently named styles pointing to the same style file (such that edits to one are reflected in the other). The best approch hear is probably to disallow users from renaming the default styles, given that deletion is already disallowed |
This message was sent by Atlassian JIRA (v1000.319.1#100012-sha1:913341f) |
