filipe created an issue |
Issue Type: |
Affects Versions: |
2.9.1 |
Assignee: |
Unassigned |
Components: |
WMS |
Created: |
25/Sep/16 10:54 AM |
Environment: |
I am a student and I am preparing a scholarly work in which I am using the GeoServer 2.9.1 . I have a problem related to the request made to the GeoServer service because i need to get the URL of the map tile service, because i have to use http://<your XYZ tile server host name>…//$ {x} /$ {y} /$ {z} to be able to configure the platform(used in the scholarly work) and access to the map on it. Can you give me indication of how i solve this problem, because i could not even through research how to solve him. Thank you in advance the care and assistance provided |
Priority: |
Reporter: |
This message was sent by Atlassian JIRA (v1000.362.1#100014-sha1:6f27b8c) |
