Jonathan Hankes created an issue |
Issue Type: |
Affects Versions: |
2.9.0 |
Assignee: |
Unassigned |
Components: |
REST |
Created: |
27/Sep/16 10:08 PM |
Priority: |
Reporter: |
When the layergroup is added and contains layers without styles, the JSON responses return HTTP 200, but are empty. XML responds normally/as expected. Problem surfaces with multiple layers ~ 5 in the layer group. there is an error in the JSON parser causing non-matching close brackets for null values, eg: `“styles”: {“style”:[“”]} ,“style”:[“”,“”]},“style”:[“”,“”]}` . ocurring in the geoserver XStreamPersister |
This message was sent by Atlassian JIRA (v1000.375.1#100014-sha1:51c0833) |
