Bjørn Sandvik created an issue |
Issue Type: |
Affects Versions: |
2.10-beta |
Assignee: |
Unassigned |
Created: |
01/Oct/16 5:03 PM |
Environment: |
OSX |
Priority: |
Reporter: |
I’m not sure if this is a bug in GeoServer or somewhere else. I saw that the “Sphere Azimuthal Equidistant” was supported from 2.10-beta, but when I combine a WMTS from GeoServer with a tileset from another service they don’t match. This works fine when I tested with another projection. I’m using ESRI:53032: https://epsg.io/53032 I’m adding this projection to epsg.properties: 53032=PROJCS[“Sphere_Azimuthal_Equidistant”,GEOGCS[“GCS_Sphere”,DATUM[“Not_specified_based_on_Authalic_Sphere”,SPHEROID[“Sphere”,6371000,0]],PRIMEM[“Greenwich”,0],UNIT[“Degree”,0.017453292519943295]],PROJECTION[“Azimuthal_Equidistant”],PARAMETER[“False_Easting”,0],PARAMETER[“False_Northing”,0],PARAMETER[“Central_Meridian”,0],PARAMETER[“Latitude_Of_Origin”,0],UNIT[“Meter”,1],AUTHORITY[“EPSG”,“53032”]] I then define a gridset/TileMatrixSet for this projection, and create a WMTS. I’m adding the same projection to Carto/PostGIS - as I want to combine layers from these two services. The extents and resolutions are the same for both services. When I add both layers they don’t match completely. When I try to do the same with another projection, “North Pole Azimuthal Equidistant” - http://epsg.io/102016, everything lines up perfectly. |
This message was sent by Atlassian JIRA (v1000.383.2#100014-sha1:783d425) |
