[Geoserver-devel] [JIRA] (GEOS-7782) Add INSPIRE grid set when INSPIRE extensions is loaded
Nuno Oliveira created an issue
GeoServer / ImprovementGEOS-7782
Issue Type:
ImprovementImprovement
Assignee:
Nuno Oliveira
Components:
INSPIRE
Created:
04/Oct/16 10:36 AM
Priority:
MediumMedium
Reporter:
Nuno Oliveira
INSPIRE requires that tiled layers use InspireCRS84Quad grid set, hence INSPIRE extension should make sure that this grid set is present and not editable by the user.
Note that is users responsibility to use the correct grid set when publishing the layers.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.383.2#100014-sha1:783d425)
Atlassian logo
