[Geoserver-devel] [JIRA] (GEOS-7788) original BandNames from coverageViews are lost, being replaced by ColorModel based names
Daniele Romagnoli created an issue
GeoServer / BugGEOS-7788
Issue Type:
BugBug
Assignee:
Unassigned
BandsNames.jpg, samplemosaic.zip
Components:
Main
Created:
07/Oct/16 11:03 AM
Priority:
MediumMedium
Reporter:
Daniele Romagnoli
Previously, when configuring a coverageView on a ImageMosaic of NetCDFs, the coverageBandDetails panel were filled with the coverage band names.
Right now, the band names are replaced by a representation of the color component.
As an instance, GRAY_INDEX, RED_BAND, GREEN_BAND, BLUE_BAND.
I think this is a consequence of
https://osgeo-org.atlassian.net/browse/GEOS-7767
Attached, a screenshot showing the old behavior (left side), and new behavior (right side).
Steps to replicate:
  1. Have GeoServer running with NetCDF extension available
  2. Configure an ImageMosaic store on top of the attached sample mosaic (need to be unzipped)
  3. create a new coverageView, by moving the NO2 and O3 bands as output bands and save
  4. Look at the band names in the Coverage Band Details panel.
Since GEOS-7767 Open introduced valid management of Alpha_band when dealing with coverageView, I wonder if we should check the input data type and color model to preserve original naming when dealing, as an instance, with NOT RGB / NOT Byte data (which will don’t have alpha in the mix)
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.383.2#100014-sha1:783d425)
Atlassian logo
