[Geoserver-devel] [JIRA] (GEOS-7790) Support for Postgres citext columns in SQLViews
david mcquillan created an issue
GeoServer / ImprovementGEOS-7790
Issue Type:
ImprovementImprovement
Affects Versions:
2.9.1, 2.9.0
Assignee:
Unassigned
Components:
Created:
07/Oct/16 8:19 PM
Environment:
Windows server 2012
tomcat 8
oracle java 8
Labels:
geoserver postgis citext
Priority:
MediumMedium
Reporter:
david mcquillan
Geoserver SQL views do not support citext column fields.
Has been tested with same data when citext sql view does not see column, when converted to text column, sql view sees column.
Symptom was noticed where a layer was styled by citext attribute, after adding to sql view layer does not display as style depends on the column citext
I notice that citext support was added to geotools in GeoToolsGEOT-4713
but it seems hasnt made it to SQL views yet
Thanks guys for the hard work.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.383.2#100014-sha1:783d425)
Atlassian logo
