[Geoserver-devel] [JIRA] (GEOS-7793) Raster oversampling + reprojection issue EPSG:2154 -> EPSG:3857
François Van Der Biest created an issue
GeoServer / BugGEOS-7793
Issue Type:
BugBug
Affects Versions:
2.8.3
Assignee:
Unassigned
Components:
WMS
Created:
11/Oct/16 11:31 AM
Environment:
jetty 9.2 / jre7 / java jai
Priority:
MediumMedium
Reporter:
A geoserver 2.8.3 instance running with jetty 9.2 / jre7 fails to display a mosaic of tiff files (https://www.ppige-npdc.fr/opendata/ortho/2012-2013/DALLES_L93_RGB_TIFF/) without vertical artifacts when reprojecting from EPSG:2154 (Lambert 93) to EPSG:3857
I’ve setup a simple ol3-based viewer showing the behavior: https://ppige-npdc.fr/opendata/ol3.html
Note that the artifacts only appear at the highest zoom levels (oversampling).
Andrea said “Without touching anything, you can try to disable the “warp/affine” merging by passing this parameter to the JVM: -DENABLE_ADVANCED_PROJECTION=false” but this did not help fix it.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.383.2#100014-sha1:783d425)
Atlassian logo
