[Geoserver-devel] [JIRA] (GEOS-7804) GeoFence and Control-flow are incompatible
Víctor González created an issue
GeoServer / ImprovementGEOS-7804
Issue Type:
ImprovementImprovement
Affects Versions:
2.9.1, 2.9.2
Assignee:
Unassigned
Components:
Control-flow, GeoFence
Created:
19/Oct/16 3:12 PM
Environment:
Latest (2.9-SNAPSHOT) probe package.
Latest (3.2.0) GeoFence deployed as a separate war and properly configured following the Github wiki.
Tomcat 8.0.36.
Java 1.8.0_101.
Linux Mint Rebecca.
Priority:
MediumMedium
Reporter:
Víctor González
If I install both, login doesn’t work; it shows the same page as if the user/password were incorrect. This appears in the log:
19 Oct 14:17:15 ERROR [auth.GeoFenceAuthenticationProvider] - Error in authenticating with GeoFence
com.google.common.util.concurrent.UncheckedExecutionException: org.springframework.remoting.RemoteAccessException: Could not access HTTP invoker remote service at [${servicesUrl}]; nested exception is java.net.MalformedURLException: no protocol: ${servicesUrl}
If I remove the control-flow jars and restart it works as expected.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.383.3#100014-sha1:d29f4bf)
Atlassian logo
