Thomas Cürten created an issue |
style multiple points with the same coordinates from a Shapefile |
Issue Type: |
Affects Versions: |
2.10-RC1 |
Assignee: |
Unassigned |
Created: |
26/Oct/16 1:19 PM |
Environment: |
CentOS 6.8 Virtual Maschine (Virtual Box) |
Labels: |
style ysld shapefile |
Priority: |
Reporter: |
I have a problem with styling multiple points that have the same coordinates in a Shapefile. Each point at one location is supposed to be symbolized by an arrow. That arrow should aim in another direction for each point. Unfortunately the Geoserver only displays one arrow for each location in the layer preview. Through the Mailinglist (https://sourceforge.net/p/geoserver/mailman/message/35439235/) I found out that it could be a Shapefile Problem. Therefore I tried the styling with an GeoPackage and that worked fine. feature-styles:
This message was sent by Atlassian JIRA (v1000.456.2#100016-sha1:c34488c) |
