[Geoserver-devel] [JIRA] (GEOS-7829) When GeoFence option "Use GeoServer roles to get authorizations" is activated users specific rules will also be selected
Nuno Oliveira created an issue
GeoServer / BugGEOS-7829
When GeoFence option “Use GeoServer roles to get authorizations” is activated users specific rules will also be selected
Issue Type:
BugBug
Assignee:
Unassigned
Components:
Community modules, GeoFence
Created:
30/Oct/16 4:37 PM
Priority:
MediumMedium
Reporter:
Nuno Oliveira
When GeoFence option “Use GeoServer roles to get authorizations” is activated, if someone defines a rule allowing a certain user to do something then everyone will inherit those permissions.
For example if we define a rule allowing a certain user to do everything everyone will be allowed to do everything.
This is a consequence of how the filter to select the matching rules is build, when the option above is activated users column is ignored:
https://github.com/geoserver/geoserver/blob/master/src/community/geofence/src/main/java/org/geoserver/geofence/GeofenceAccessManager.java#L394-L423
To reproduce this issue just activate the option “Use GeoServer roles to get authorizations” on GeoFence configuration page and define a single rule allowing only a specific user to do everything. Logout and try to do something, no restrictions will be applied.
The original use case that motivated this option was very specific and not needed anymore.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.482.3#100017-sha1:2ae3eee)
Atlassian logo
