[Geoserver-devel] [JIRA] (GEOS-7839) Modifying CatalogInfo objects with the REST API makes them permanently unusable
Torben Barsballe created an issue
GeoServer / BugGEOS-7839
Issue Type:
BugBug
Assignee:
Unassigned
Created:
07/Nov/16 9:51 PM
Environment:
If you use the REST API to modify a LayerInfo object, subsequent request (get, modify, delete, etc.) will fail, with the error
No property null found on entity class com.sun.proxy.$Proxy171 to bind constructor parameter to!
This occurs because the AttributionInfo property of the LayerInfo object is wrapped in a proxy when it gets saved to Redis after the layer is modified.
This error occurs even if you don’t modify the AttributionInfo.
While I have not tested, I assume this also affects other CatalogInfo objects that have info objects as properties, such as LayerGroupInfo or StyleInfo.
Priority:
MediumMedium
Reporter:
Torben Barsballe
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.499.4#100018-sha1:b6a952e)
Atlassian logo
