Julien Cigar created an issue |
Issue Type: |
Affects Versions: |
2.10.0 |
Assignee: |
Unassigned |
Components: |
Global |
Created: |
08/Nov/16 3:20 PM |
Environment: |
Geoserver 2.10.0, FreeBSD, jails, NFS4, OpenJDK8 |
Priority: |
Reporter: |
Hello, I’d like to setup some HA (active/passive) on our current Geoserver installation. For that I have configured two Geoserver instances in two FreeBSD jails: java1.prod.lan is the ACTIVE instance and java2.prod.lan is the PASSIVE instance. The two instances share the same data_dir, accessible through /filer/geoserver/data_dir which is a ZFS FS exported through NFS. To avoid possible corruption the shared data_dir is mounted read-only on the PASSIVE instance, but unfortunately it doesn’t work (fall back to embedded data directory) because of the following code: The problematic code is:
My goal was to add stores, layers, etc on the ACTIVE node and then just log-in on the PASSIVE node and reload the catalog … So my question is: why does Geoserver absolutely needs a writable data_dir/ for a read-only instance ? FYT this is the full log when I start the PASSIVE node: https://gist.github.com/silenius/f37e391e448d8fa3f9a6f88dac37e53a Thanks, |
This message was sent by Atlassian JIRA (v1000.526.0#100018-sha1:e9d616c) |
