[Geoserver-devel] [JIRA] (GEOS-7843) Renaming layer causes GWC to fall out of sync
Jody Garnett [Administrator] created an issue
GeoServer / ImprovementGEOS-7843
Issue Type:
ImprovementImprovement
Affects Versions:
2.9.2
Assignee:
Kevin Smith
Components:
Configuration, GWC
Created:
09/Nov/16 8:19 PM
Priority:
MediumMedium
Reporter:
This is the second issue reported against a “many workspace, same stores and layers in each” configuration (see GEOS-7682 In Progress ). Renaming one of the workspaces from “Matheson” to “matheson”, and then subsequently deleting on of the layers did not properly clean up the GWC layer leaving it pointing at a layer that does not exist.
GWC may need to be told to listen for workspace rename events for workspaces that contain layers it’s caching so that it can rename its own layers and fix any listeners it’s using to watch for deletes.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.526.0#100018-sha1:e9d616c)
Atlassian logo
