Invalid SQL “auto_increment” causes PostGisRoleServiceTest and PostGisUserDetailsServiceTest to fail when online tests against PostGIS are configured by a valid ~/.geoserver/postgis.properties :
Results :
Tests in error:
testRoleDatabaseSetup(org.geoserver.security.jdbc.PostGisRoleServiceTest): org.postgresql.util.PSQLException: ERROR: syntax error at or near "auto_increment"(..)
testIsModified(org.geoserver.security.jdbc.PostGisRoleServiceTest): org.postgresql.util.PSQLException: ERROR: syntax error at or near "auto_increment"(..)
testInsert(org.geoserver.security.jdbc.PostGisRoleServiceTest): org.postgresql.util.PSQLException: ERROR: syntax error at or near "auto_increment"(..)
testModify(org.geoserver.security.jdbc.PostGisRoleServiceTest): org.postgresql.util.PSQLException: ERROR: syntax error at or near "auto_increment"(..)
testRemove(org.geoserver.security.jdbc.PostGisRoleServiceTest): org.postgresql.util.PSQLException: ERROR: syntax error at or near "auto_increment"(..)
testConfiguration(org.geoserver.security.jdbc.PostGisUserDetailsServiceTest): org.postgresql.util.PSQLException: ERROR: syntax error at or near "auto_increment"(..)
testRoleCalculation(org.geoserver.security.jdbc.PostGisUserDetailsServiceTest): org.postgresql.util.PSQLException: ERROR: syntax error at or near "auto_increment"(..)
testPersonalizedRoles(org.geoserver.security.jdbc.PostGisUserDetailsServiceTest): org.postgresql.util.PSQLException: ERROR: syntax error at or near "auto_increment"(..)
Tests run: 114, Failures: 0, Errors: 8, Skipped: 64
I think PostgreSQL uses serial not auto_increment .
