[Geoserver-devel] [JIRA] (GEOS-7856) Imagemosaic: Input Transparent Color for 32bit tifs
Sabine Helm created an issue
GeoServer / ImprovementGEOS-7856
Issue Type:
ImprovementImprovement
Affects Versions:
2.7.5
Assignee:
Unassigned
gtiff1_sub2.tif, gtiff2_sub2.tif
Components:
image mosaic
Created:
16/Nov/16 9:39 AM
Environment:
Ubuntu 14.04, Tomcat 7, Oracle Java 7
Priority:
MediumMedium
Reporter:
Sabine Helm
I want to create an imagemosaic with several 32bit GeoTiffs. The single tifs overlap at the edges and partly have no data values there which appear in the mosaic. To avoid that the possibility to set an “Input Transparent Color” for float values would be great.
I create this Issue as proposed from Simone Giannecchini.
See also http://osgeo-org.1560.x6.nabble.com/Imagemosaic-Input-Transparent-Color-for-32bit-tifs-td5292363.html
I attached two small sample images.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.552.1#100018-sha1:c06db68)
Atlassian logo
