If you delete a layerGroup that is contained within another layerGroup by any method that uses Catalog.remove() (rather than CascadingDeleteVisitor), you will corrupt the catalog; The deleteion will succed but not update the containing layer group, meaning that any further events to access the remaining layer group will fail with the following error:
Caused by: java.lang.NullPointerException
at org.geoserver.security.SecureCatalogImpl.checkAccess(SecureCatalogImpl.java:631)
at org.geoserver.security.SecureCatalogImpl.checkAccess(SecureCatalogImpl.java:490)
at org.geoserver.security.SecureCatalogImpl.checkAccess(SecureCatalogImpl.java:634)
at org.geoserver.security.SecureCatalogImpl.filterGroups(SecureCatalogImpl.java:959)
at org.geoserver.security.SecureCatalogImpl.getLayerGroupsByWorkspace(SecureCatalogImpl.java:328)
at org.geoserver.catalog.impl.AbstractFilteredCatalog.getLayerGroupsByWorkspace(AbstractFilteredCatalog.java:259)
at org.geoserver.catalog.impl.AbstractCatalogDecorator.getLayerGroupsByWorkspace(AbstractCatalogDecorator.java:466)
at org.geoserver.catalog.impl.LocalWorkspaceCatalog.getLayerGroupsByWorkspace(LocalWorkspaceCatalog.java:210)
at org.geoserver.catalog.rest.LayerGroupListResource.handleListGet(LayerGroupListResource.java:32)
at org.geoserver.catalog.rest.LayerGroupListResource.handleListGet(LayerGroupListResource.java:1)
at org.geoserver.catalog.rest.AbstractCatalogListResource.handleObjectGet(AbstractCatalogListResource.java:41)
at org.geoserver.rest.ReflectiveResource.handleGet(ReflectiveResource.java:89)
... 89 more
This occurs because the LayerGroup still holds a reference to the deleted layer group, so we get stuck with a ResolvingProxy containing “null” in place of the deleted layerGroup.
