[Geoserver-devel] [JIRA] (GEOS-7926) Reloading GeoServer re-enables all disabled WMTS services
Nuno Oliveira created an issue
GeoServer / BugGEOS-7926
Issue Type:
BugBug
Assignee:
Unassigned
Components:
GWC
Created:
10/Jan/17 11:52 PM
Fix Versions:
2.9.4, 2.11-beta, 2.10.2
Priority:
MediumMedium
Reporter:
Nuno Oliveira
To reproduce this issue disable a WTMS service (a global one or a virtual one) and restart GeoServer. The disabled WMTS service will be re-enable.
This happens because the service initialization, which is supposed to only fill the blanks, is blindly enabling the service:
https://github.com/geoserver/geoserver/blob/master/src/gwc/src/main/java/org/geoserver/gwc/wmts/WMTSXStreamLoader.java#L38
This is situation was not catch by the unit tests because the initialization is not invoked as it should be:
https://github.com/geoserver/geoserver/blob/master/src/gwc/src/test/java/org/geoserver/gwc/wmts/WMTSXStreamLoaderTest.java#L29
Mailing list discussion:
http://osgeo-org.1560.x6.nabble.com/Disabling-WMTS-in-GeoServer-2-10-td5302877.html
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.670.2#100024-sha1:3793824)
Atlassian logo
