[Geoserver-devel] [JIRA] (GEOS-7934) WPS fails to start if you have removed a process
Ian Turton created an issue
GeoServer / BugGEOS-7934
Issue Type:
BugBug
Affects Versions:
2.10.1
Assignee:
Unassigned
log.txt
Components:
WPS
Created:
18/Jan/17 11:24 AM
Environment:
Windows Server 2012, Oracle Java 1.8_111
Priority:
MediumMedium
Reporter:
Ian Turton
If for some reason you remove the jar that supplies a WPS process GeoServer fails to initialize the WPS on restart with error below.
Workround is to remove the processGroup element from $DATA_DIR/wps.xml
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.695.1#100025-sha1:c4480eb)
Atlassian logo
