There’s an error in the caller IP address resolution when the monitoring plugin is installed:
{{2017-01-20 12:13:52,028 WARN [geoserver.monitor] - Post process task failed
java.lang.IllegalStateException: No thread-bound request found: Are you referring to request attributes outside of an actual web request, or processing a request outside of the originally receiving thread? If you are actually operating within a web request and still receive this message, your code is probably running outside of DispatcherServlet/DispatcherPortlet: In this case, use RequestContextListener or RequestContextFilter to expose the current request.
at org.springframework.web.context.request.RequestContextHolder.currentRequestAttributes(RequestContextHolder.java:131)
at org.geoserver.geofence.GeofenceAccessManager.retrieveCallerIpAddress(GeofenceAccessManager.java:253)
at org.geoserver.geofence.GeofenceAccessManager.getAccessLimits(GeofenceAccessManager.java:367)
at org.geoserver.geofence.GeofenceAccessManager.getAccessLimits(GeofenceAccessManager.java:293)
at org.geoserver.security.ResourceAccessManagerWrapper.getAccessLimits(ResourceAccessManagerWrapper.java:214)
at org.geoserver.security.CatalogFilterAccessManager.getAccessLimits(CatalogFilterAccessManager.java:56)
at org.geoserver.security.SecureCatalogImpl.buildWrapperPolicy(SecureCatalogImpl.java:806)
at org.geoserver.security.SecureCatalogImpl.buildWrapperPolicy(SecureCatalogImpl.java:770)
at org.geoserver.security.SecureCatalogImpl.checkAccess(SecureCatalogImpl.java:594)
at org.geoserver.security.SecureCatalogImpl.getLayerByName(SecureCatalogImpl.java:295)
at org.geoserver.catalog.impl.AbstractFilteredCatalog.getLayerByName(AbstractFilteredCatalog.java:225)
at org.geoserver.catalog.impl.AbstractCatalogDecorator.getLayerByName(AbstractCatalogDecorator.java:384)
at org.geoserver.catalog.impl.LocalWorkspaceCatalog.getLayerByName(LocalWorkspaceCatalog.java:92)
at org.geoserver.monitor.LayerNameNormalizer.run(LayerNameNormalizer.java:43)
at org.geoserver.monitor.MonitorFilter$PostProcessTask.run(MonitorFilter.java:246)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1145)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:615)
at java.lang.Thread.run(Thread.java:745)}}
