Roy Højgaard created an issue |
Error with labeling algorithm, ghost labels at bottom of tiles. |
Issue Type: |
Affects Versions: |
2.7.2, 2.10.1 |
Assignee: |
Unassigned |
Created: |
22/Jan/17 11:50 PM |
Environment: |
Centos Linux release 7.2.1511 64 bit, Tomcat 7.0.54 |
Priority: |
Reporter: |
Dear All. Thank you so much for GeoServer. I have been using it with great success for many years! There seems however to be an issue with the line labeling algorithm. Please have a look at the attached screenshot. The issue has existed, from around 2.7.2 until and including the current version (2.10.1). Because if this, I am forced to use 2.7.1.1. The road data comes straight from OSM. Notice all the “ghost labels”, which are all located at the bottom of individual tiles. As far as I can conclude, this only happens when the label does not fit completely within a tile. The label algorithm seems to give up, and just drop the label at the bottom of the tile. It happens with and without using GWC. |
This message was sent by Atlassian JIRA (v1000.695.2#100025-sha1:d830fc4) |
