Eduardo Suarez-Santana created an issue |
Issue Type: |
Affects Versions: |
2.10.1 |
Assignee: |
Unassigned |
Components: |
GWC |
Created: |
23/Jan/17 2:11 PM |
Priority: |
Reporter: |
When working with virtual workspace service WMTS, that is, something like: http://localhost:8080/geoserver/myworkspace/gwc/service/wmts?SERVICE=WMTS&… layer are sent in capabilities without workspace prefix (GeoServerTileLayer.java): {{ @Override { // this is a get capabilities request, we need to check if we are in the context of virtual service return getNoPrefixedNameIfVirtualService(); } return info.getName(); However, when processing GetFeaturetInfo, layer name with workspace prefix is required, otherwise you get a 400 error: LAYER xxxx is not known. WMTSService.java: {{ String layer = values.get(“layer”); { throw new OWSException(400, “MissingParameterValue”, “LAYER”, “Missing LAYER parameter”); } TileLayer tileLayer = null; try { tileLayer = tld.getTileLayer(layer); } catch (GeoWebCacheException e) { throw new OWSException(400, “InvalidParameterValue”, “LAYER”, “LAYER " + layer + " is not known.”); } }} Prefix must be applied in this case for the virtual service to work. |
This message was sent by Atlassian JIRA (v1000.695.3#100025-sha1:c635a15) |
