david mcquillan created an issue |
Issue Type: |
Affects Versions: |
2.8.5, 2.10.0, 2.10.1 |
Assignee: |
Unassigned |
Components: |
Image Pyramid |
Created: |
25/Jan/17 4:44 PM |
Environment: |
Ubuntu 14.04 64bit 4GB ram VM running on windows server 2012 hyper-v |
Priority: |
Reporter: |
We have recently been implementing raster support in our application, when loading a image pyramid in geoserver 2.10.1 as a wms layer tiled, the tiles do not load properly at scales closer than 1:273k inclusive. (I have tested and found the same issue in 2.8.5, 2.10.0,2.10.1 and the 25thJan Nightly - all on the same data directory) This issue does not occur in geoserver version 2.81 with 4 levels The data being served is a 4 band geotiff sentinel output in 3857 imagepyramid creation settings using gdal_retile.py were: I have 2 test instances of the data to show issues, to see the issue tiling must be on The settings for each seem to be the same, David |
This message was sent by Atlassian JIRA (v1000.718.1#100026-sha1:45ff291) |
