[Geoserver-devel] [JIRA] (GEOS-7950) GeoFence: compatibility issue with controlflow
Emanuele Tajariol created an issue
GeoServer / BugGEOS-7950
Issue Type:
BugBug
Affects Versions:
2.10.1
Assignee:
Unassigned
Components:
Control-flow, GeoFence
Created:
26/Jan/17 2:50 PM
Priority:
MediumMedium
Reporter:
Emanuele Tajariol
At boot time there are problems with a PropertyPlaceholderConfigurer:
AVVERTENZA: bean lookup error
org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'rememberMeServices' defined in URL [jar:file:/var/lib/tomcat/geoserver/webapps/geoserver_test/WEB-INF/lib/gs-main-2.10-SNAPSHOT.jar!/applicationSecurityContext.xml]: Cannot resolve reference to bean 'geoServerSecurityManager' while setting constructor argument; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'authenticationManager' defined in URL [jar:file:/var/lib/tomcat/geoserver/webapps/geoserver_test/WEB-INF/lib/gs-main-2.10-SNAPSHOT.jar!/applicationSecurityContext.xml]: Initialization of bean failed; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geofenceFilter' defined in URL [jar:file:/var/lib/tomcat/geoserver/webapps/geoserver_test/WEB-INF/lib/gs-geofence-2.10-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean '${ruleReaderFrontend}' while setting bean property 'ruleReaderService'; nested exception is org.springframework.beans.factory.NoSuchBeanDefinitionException: No bean named '${ruleReaderFrontend}' is defined
Related cause: org.springframework.beans.factory.BeanCurrentlyInCreationException: Error creating bean with name 'rememberMeServices': Requested bean is currently in creation: Is there an unresolvable circular reference?
        at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:359)
        at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:108)
        at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:648)
        at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:140)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:1143)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:1046)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.getSingletonFactoryBeanForTypeCheck(AbstractAutowireCapableBeanFactory.java:865)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.getTypeForFactoryBean(AbstractAutowireCapableBeanFactory.java:796)
        at org.springframework.beans.factory.support.AbstractBeanFactory.isTypeMatch(AbstractBeanFactory.java:544)
        at org.springframework.beans.factory.support.DefaultListableBeanFactory.doGetBeanNamesForType(DefaultListableBeanFactory.java:447)
        at org.springframework.beans.factory.support.DefaultListableBeanFactory.getBeanNamesForType(DefaultListableBeanFactory.java:415)
        at org.springframework.beans.factory.support.DefaultListableBeanFactory.getBeanNamesForType(DefaultListableBeanFactory.java:409)
        at org.springframework.context.support.AbstractApplicationContext.getBeanNamesForType(AbstractApplicationContext.java:1150)
        at org.geoserver.platform.GeoServerExtensions.extensionNames(GeoServerExtensions.java:211)
        at org.geoserver.platform.GeoServerExtensions.extensions(GeoServerExtensions.java:126)
        at org.geoserver.platform.GeoServerExtensions.bean(GeoServerExtensions.java:332)
        at org.geoserver.flow.ControlFlowCallback.postProcessBeanDefinitionRegistry(ControlFlowCallback.java:210)
        at org.springframework.context.support.PostProcessorRegistrationDelegate.invokeBeanFactoryPostProcessors(PostProcessorRegistrationDelegate.java:123)
        at org.springframework.context.support.AbstractApplicationContext.invokeBeanFactoryPostProcessors(AbstractApplicationContext.java:678)
        at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:520)
        at org.springframework.web.context.ContextLoader.configureAndRefreshWebApplicationContext(ContextLoader.java:444)
        at org.springframework.web.context.ContextLoader.initWebApplicationContext(ContextLoader.java:326)
        at org.springframework.web.context.ContextLoaderListener.contextInitialized(ContextLoaderListener.java:107)
        at org.geoserver.platform.GeoServerContextLoaderListener.contextInitialized(GeoServerContextLoaderListener.java:23)
        at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:5118)
        at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5634)
        at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:145)
        at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:899)
        at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:875)
        at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:652)
        at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:1092)
        at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1984)
        at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511)
        at java.util.concurrent.FutureTask.run(FutureTask.java:266)
        at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142)
        at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617)
        at java.lang.Thread.run(Thread.java:745)
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'authenticationManager' defined in URL [jar:file:/var/lib/tomcat/geoserver/webapps/geoserver_test/WEB-INF/lib/gs-main-2.10-SNAPSHOT.jar!/applicationSecurityContext.xml]: Initialization of bean failed; nested exception is org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geofenceFilter' defined in URL [jar:file:/var/lib/tomcat/geoserver/webapps/geoserver_test/WEB-INF/lib/gs-geofence-2.10-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean '${ruleReaderFrontend}' while setting bean property 'ruleReaderService'; nested exception is org.springframework.beans.factory.NoSuchBeanDefinitionException: No bean named '${ruleReaderFrontend}' is defined
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:553)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:482)
        at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:306)
        at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:230)
        at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:302)
        at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:197)
        at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:351)
        ... 36 more
Caused by: org.springframework.beans.factory.BeanCreationException: Error creating bean with name 'geofenceFilter' defined in URL [jar:file:/var/lib/tomcat/geoserver/webapps/geoserver_test/WEB-INF/lib/gs-geofence-2.10-SNAPSHOT.jar!/applicationContext.xml]: Cannot resolve reference to bean '${ruleReaderFrontend}' while setting bean property 'ruleReaderService'; nested exception is org.springframework.beans.factory.NoSuchBeanDefinitionException: No bean named '${ruleReaderFrontend}' is defined
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1481)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1226)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:543)
        at org.springframework.context.support.AbstractApplicationContext.getBean(AbstractApplicationContext.java:1054)
        at org.geoserver.platform.GeoServerExtensions.getBean(GeoServerExtensions.java:238)
        at org.geoserver.platform.GeoServerExtensions.extensions(GeoServerExtensions.java:139)
        at org.geoserver.security.GeoServerSecurityManager.lookupSecurityProviders(GeoServerSecurityManager.java:2754)
        at org.geoserver.security.GeoServerSecurityManager.buildPersister(GeoServerSecurityManager.java:2811)
        at org.geoserver.security.GeoServerSecurityManager.setApplicationContext(GeoServerSecurityManager.java:363)
        at org.springframework.context.support.ApplicationContextAwareProcessor.invokeAwareInterfaces(ApplicationContextAwareProcessor.java:119)
        at org.springframework.context.support.ApplicationContextAwareProcessor.postProcessBeforeInitialization(ApplicationContextAwareProcessor.java:94)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:408)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1570)
        at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:545)
        ... 42 more
Caused by: org.springframework.beans.factory.NoSuchBeanDefinitionException: No bean named '${ruleReaderFrontend}' is defined
        at org.springframework.beans.factory.support.DefaultListableBeanFactory.getBeanDefinition(DefaultListableBeanFactory.java:698)
        at org.springframework.beans.factory.support.AbstractBeanFactory.getMergedLocalBeanDefinition(AbstractBeanFactory.java:1175)
        at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:284)
        ... 62 more
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.718.1#100026-sha1:45ff291)
Atlassian logo
