Nuno Oliveira created an issue |
Add a WMS vendor FORMAT parameter to force the return of WMS 1.1.1 capabilities in text/xml |
Issue Type: |
Assignee: |
Components: |
WMS |
Created: |
01/Feb/17 5:06 PM |
Priority: |
Reporter: |
The WMS 1.1.1 GetCapabilities XML response uses the OGC specific mime type application/vnd.ogc.wms_xml. I would like to propose a new WMS vendor parameter named FORMAT that can be used to force the response mime type to something more well recognized like text/xml. Note that WMS 1.3.0 GetCapabilities result already uses text/xml. This will imply implementing the handling of the FORMAT parameter when generating the GetCapabilities response for WMS 1.1.1 and adding text/xml as a supported mime type for WMS 1.1.1 GetCapabilities result. In the case were an invalid mime type is requested we will log an warning and fall-back on the OGC default one. Mailing list discussion: http://osgeo-org.1560.x6.nabble.com/Add-a-WMS-vendor-FORMAT-parameter-to-force-the-return-of-WMS-1-1-1-capabilities-in-text-xml-td5305506.html |
This message was sent by Atlassian JIRA (v1000.718.4#100026-sha1:69a2752) |
