Andrea Aime [Administrator] created an issue |
Reducing output size of PDF with graphic fills by using tiling patterns |
Issue Type: |
Assignee: |
Unassigned |
Components: |
WMS |
Created: |
07/Feb/17 12:15 PM |
Priority: |
Reporter: |
The PDF specification allows to use a “tiling pattern” notion in which a repeated block of PDF can be used to fill a shape, retaining its vector nature. This can be used to drastically reduce the size of PDF outputs in which the style uses a SVG or Mark based graphic fill. |
This message was sent by Atlassian JIRA (v1000.747.0#100028-sha1:6f58f37) |
