[Geoserver-devel] [JIRA] (GEOS-7981) imageio-ext-gdalgeotiff.jar creates classpath conflicts and gs fails at startup
Damiano Giampaoli created an issue
GeoServer / BugGEOS-7981
Issue Type:
BugBug
Affects Versions:
2.10-RC1, 2.10.0, 2.10.1
Assignee:
Unassigned
Components:
gdal-wcs
Created:
08/Feb/17 3:54 PM
Priority:
HighHigh
Reporter:
Damiano Giampaoli
When the GDAL extension is installed the presence of the imageio-ext-gdalgeotiff.jar in the classpath can cause classpath loading problems: only classes in imageio-ext-geotiff.jar should be loaded.
When this happen (the cp conflict is not predictable and the error may occurs depending on which layers are loaded in GS) geoserver fails at startup (see this stacktrace)
Since the imageio-ext-gdalgeotiff dependency is never used it can be removed explicitly from the gdal extension zip pkg and from the related geootols module’s pom (see related issue)
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.747.0#100028-sha1:6f58f37)
Atlassian logo
