Paul van Genuchten created an issue |
Issue Type: |
Assignee: |
Unassigned |
Components: |
Configuration |
Created: |
10/Feb/17 10:21 AM |
Priority: |
Reporter: |
by default geoserver shows layers alphabetically sorted in wms/wfs/wcs capabilities in wms you can change this behaviour by adding all layers to a (container-tree) layer group and sort the layers as part of the layergroup however i would also like to introduce this behaviour on the rootlayer/toplayer, so we don’t need an additional layergroup-level. on the mailinglist it was suggested to add a numeric field to each layer configuration that contains a number by which the layer is ordered. In later iterations the UI to fill that number can be optimised to show for example an advanced tree view. activities:
comments:
the use case for this is for example when a server contains layers forest_2016, forest_2015, forest_2014… etc, in that case they would want forest_2016 on top so it is easy to select when adding that service to a map (in for example qgis) this issue is an alternative to https://osgeo-org.atlassian.net/browse/GEOS-7971, which was not adviced in the mailinglist |
This message was sent by Atlassian JIRA (v1000.747.1#100028-sha1:3d05bd6) |
