[Geoserver-devel] [JIRA] (GEOS-7997) Vector Tiles are not displaying correctly using Mapbox GL
Mr. McNuggies created an issue
GeoServer / BugGEOS-7997
Issue Type:
BugBug
Affects Versions:
2.11-beta
Assignee:
Unassigned
Components:
Vector Tiles
Created:
15/Feb/17 9:25 PM
Environment:
Linux
Priority:
HighHigh
Reporter:
Mr. McNuggies
Short Synopsis
When trying to load geoserver vector tiles into the browser using mapbox GL the results are unusable. To see the javascript code look at the bottom of this report.
Detailed Synopsis
There seems to be a huge alignment and redrawing issue (the prime meridian is over texas). When the user zooms it seems to be aligning and drawing the new vector tiles to the south of the old tiles (see photos). This bug might be related to https://osgeo-org.atlassian.net/browse/GEOS-7920. The new tiles might be drawn offscreen and not updated on Andre Schardong screen … hence it looks terrible on his screen. Might be related to ‘vector tile source “osm” layer “states” does not use vector tile spec v2 and therefore may have some rendering errors’ error received in the console.
JS Code
  var simple = {
    "version": 8,
    "sources": {
        "osm": {
            "type": "vector",
            "tiles": ["http://xxxxx/geoserver211/gwc/service/tms/1.0.0/topp:states@anonymised.com:4326@anonymised.com/{z}/{x}/{y}.pbf"]
    "layers": [
            "id": "background",
            "type": "background",
            "paint": {
                "background-color": "#ffffff"
            "id": "states",
            "type": "fill",
            "source": "osm",
            "source-layer": "states",
            "filter": ["==", "$type", "Polygon"],
            "paint": {
                "fill-color": "#3887be"
  //map info here
  map = new mapboxgl.Map({
     container: 'map', // container id
     style: simple, //stylesheet location
     center: [0, 0], // starting position[35.890, -75.664]
     zoom: 0, // starting zoom
     hash: true,
     minZoom: 0,
     maxZoom: 22,
     preserveDrawingBuffer: true
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.747.1#100028-sha1:3d05bd6)
Atlassian logo
