[Geoserver-devel] [JIRA] (GEOS-8000) WPS process cleanup error - date paring error
Bjorn Nilsson created an issue
GeoServer / BugGEOS-8000
Issue Type:
BugBug
Affects Versions:
2.9.3
Assignee:
Unassigned
Components:
WPS
Created:
21/Feb/17 2:47 PM
Environment:
OS Name Microsoft Windows Server 2008 R2 Standard
Version 6.1.7600 Build 7600
Java 1.8.0_73 x64
Tomcat 7.0.75 x64
geoserver-2.9.3
geoserver-2.9.3-wps-plugin
Bygginformation
Version
2.9.3
Git revision
0d588545aeb7550c04ce74ea8dbb932e3512f0dd
Byggdatum
24-Nov-2016 20:02
GeoTools-version
15.3 (rev 2db372589d85dfdc256a292f7cc11e8f81cdcdf2)
GeoWebCache-version
1.9.2 (rev 1.9.x/b259119a71b04329bd939d0ec791de997c5b0dbf)
Priority:
MediumMedium
Reporter:
Bjorn Nilsson
After successful execution of WPS processes the Geoserver Process status log in the UI fill up. No entries are ever deleted due to a date parsing error.
errors from geoserver log:
2017-02-21 11:33:01,253 DEBUG [geoserver.wps] - Removing statuses matching [[[ NOT [ completionTime IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl@anonymised.com] AND [[ NOT [ lastUpdated IS NULL ] ] AND org.geotools.filter.temporal.BeforeImpl@anonymised.com]]
2017-02-21 11:33:01,253 DEBUG [geotools.util] - InterpolationConverterFactory can be applied from Strings to Interpolation only.
2017-02-21 11:33:01,253 DEBUG [geotools.util] - CRSConverterFactory can be applied from Strings to CRS only.
2017-02-21 11:33:01,253 TRACE [geotools.util] - Error applying the converter class org.geotools.xml.XmlConverterFactory$XmlConverter on (Tue Feb 21 11:23:03 CET 2017,class java.util.Date)
java.lang.IllegalArgumentException: Failed to parse time Tue Feb 21 11:23:03 CET 2017 at:Tue Feb 21 11:23:03 CET 2017
at org.geotools.xml.impl.DatatypeConverterImpl.parseTime(DatatypeConverterImpl.java:189)
at org.geotools.xml.XmlConverterFactory$XmlConverter.convertFromString(XmlConverterFactory.java:123)
at org.geotools.xml.XmlConverterFactory$XmlConverter.convert(XmlConverterFactory.java:76)
at org.geotools.util.Converters.convert(Converters.java:168)
at org.geotools.util.Converters.convert(Converters.java:129)
at org.geotools.temporal.TemporalConverterFactory$2.convert(TemporalConverterFactory.java:51)
at org.geoserver.wps.property.BeanPropertyAccessor.get(BeanPropertyAccessor.java:37)
at org.geotools.filter.AttributeExpressionImpl.tryAccessor(AttributeExpressionImpl.java:248)
at org.geotools.filter.AttributeExpressionImpl.evaluate(AttributeExpressionImpl.java:208)
at org.geotools.filter.temporal.BinaryTemporalOperatorImpl.toInstant(BinaryTemporalOperatorImpl.java:64)
at org.geotools.filter.temporal.BinaryTemporalOperatorImpl.toTemporal(BinaryTemporalOperatorImpl.java:77)
at org.geotools.filter.temporal.BinaryTemporalOperatorImpl.evaluate(BinaryTemporalOperatorImpl.java:52)
at org.geotools.filter.AndImpl.evaluate(AndImpl.java:44)
at org.geoserver.wps.MemoryProcessStatusStore.remove(MemoryProcessStatusStore.java:74)
at org.geoserver.wps.executor.ProcessStatusTracker.cleanExpiredStatuses(ProcessStatusTracker.java:135)
at org.geoserver.wps.WPSStorageCleaner.run(WPSStorageCleaner.java:50)
at org.springframework.scheduling.support.DelegatingErrorHandlingRunnable.run(DelegatingErrorHandlingRunnable.java:54)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask.runAndReset(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
I wonder if this ever worked with java 8, but maybe I’m missing something. Below are some research from the code base:
According to the API doc for java 8 for java.util.Date
public String toString()
Converts this Date object to a String of the form:
dow mon dd hh:mm:ss zzz yyyy
This comment from the source below clearly states that a date string on the form:
would never be parsed correctly by this method
geotools/modules/extension/xsd/xsd-core/src/main/java/org/geotools/xml/impl/DatatypeConverterImpl.java
/** <p>Parses the lexical representation of the given dateTime value
  • and converts it into an instance of {@link java.util.Calendar}.
    • Valid lexical representations of a dateTime value include
    • <pre>
    • YYYY-MM-DDThh:mm:ss
    • YYYY-MM-DDThh:mm:ss.sss
    • YYYY-MM-DDThh:mm:ssZ
    • YYYY-MM-DDThh:mm:ss-01:00
    • </pre>
    • The former examples are all specified in UTC time. The last example
    • uses a negative offset of one hour to UTC.</p>
    • @param arg0 The input string being parsed.
    • @param lenient parameter used for allowing lenient parsing
    • @return The input string converted into an instance of
    • {@link java.util.Calendar}
  • @see javax.xml.bind.ParseConversionEvent
    public Calendar parseDateTime(String arg0, boolean lenient)
    Unknown macro: { XsDateTimeFormat format = new XsDateTimeFormat(); ParsePosition pos = new ParsePosition(0); Calendar cal = (Calendar) format.parseObject(arg0, pos, lenient); if (cal == null) { throw new IllegalArgumentException(“Failed to parse dateTime " + arg0 + " at:” + arg0.substring(pos.getErrorIndex())); } return cal; }
If we follow the stacktrace a bit furhter there seems to be an explicit to String cast in the XmlConverter.convert method.
geotools/modules/extension/xsd/xsd-core/src/main/java/org/geotools/xml/XmlConverterFactory.java
public class XmlConverterFactory implements ConverterFactory {
public Converter createConverter(Class source, Class target, Hints hints) {
// make sure either source or target is String in order not to step over
// TemporalConverterFactory
if (String.class.equals(target)) {
if (java.util.Date.class.isAssignableFrom(source)
Calendar.class.isAssignableFrom(source)) { return new XmlConverter(); }
} else if (String.class.equals(source)) {
if (java.util.Date.class.isAssignableFrom(target)
|| Calendar.class.isAssignableFrom(target)) { return new XmlConverter(); }
return null;
static class XmlConverter implements Converter {
public Object convert(Object source, Class target)
throws Exception {
{ return convertToString(source); }
return convertFromString((String) source, target);
private Object convertFromString(final String source, final Class<?> target) {
// don’t bother performing conversions if the target types are not dates/times
if(!Calendar.class.equals(target) && !Date.class.isAssignableFrom(target))
return null;
//JD: this is a bit of a hack but delegate to the
// commons converter in case we are executing first.
try {
Converter converter = new CommonsConverterFactory().createConverter(String.class,
target, null);
if (converter != null) {
Object converted = null;
try
{ converted = converter.convert(source, target); }
catch (Exception e)
{ //ignore }
if (converted != null)
{ return converted; }
catch(Exception e)
{ //fall through to jaxb parsing }
Calendar date;
//try parsing as dateTime
try {
try
{ date = DatatypeConverterImpl.getInstance().parseDateTime(source); }
catch(Exception e)
{ //try as just date date = DatatypeConverterImpl.getInstance().parseDate(source); }
} catch (Exception e)
{ //try as just time date = DatatypeConverterImpl.getInstance().parseTime(source); }
if (Calendar.class.equals(target))
{ return date; }
if (Date.class.isAssignableFrom(target)) {
Date time = date.getTime();
//check for subclasses
if (java.sql.Date.class.equals(target))
{ return new java.sql.Date(time.getTime()); }
if (Time.class.equals(target))
{ return new Time(time.getTime()); }
if (Timestamp.class.equals(target))
{ return new Timestamp(time.getTime()); }
return time;
return null;
private String convertToString(Object unconvertedValue) {
String textValue = null;
if (unconvertedValue instanceof Calendar)
{ Calendar cal = (Calendar) unconvertedValue; textValue = DatatypeConverterImpl.getInstance().printDateTime(cal); }
else if(unconvertedValue instanceof java.sql.Date){
DatatypeConverterImpl converter = DatatypeConverterImpl.getInstance();
Object hint = Hints.getSystemDefault(Hints.LOCAL_DATE_TIME_HANDLING);
Calendar cal;
if(Boolean.TRUE.equals(hint))
{ cal = Calendar.getInstance(); }
else
{ cal = Calendar.getInstance(TimeZone.getTimeZone(“GMT”)); }
cal.setTimeInMillis(((java.util.Date) unconvertedValue).getTime());
textValue = converter.printDate(cal);
} else if (unconvertedValue instanceof java.util.Date) {
Calendar cal = Calendar.getInstance(TimeZone.getTimeZone(“GMT”));
if (unconvertedValue instanceof java.sql.Time)
{ textValue = converter.printTime(cal); }
else
{ // java.util.Date and java.sql.TimeStamp textValue = converter.printDateTime(cal); }
return textValue;
geotools/modules/library/main/src/main/java/org/geotools/temporal/TemporalConverterFactory.java
public class TemporalConverterFactory implements ConverterFactory {
static Converter dateToInstant = new Converter() {
public T convert(Object source, Class target) throws Exception
{ return (T) new DefaultInstant(new DefaultPosition((Date)source)); }
static Converter stringToInstant = new Converter() {
{ //first go to java.util.Date Date d = Converters.convert(source, Date.class); //then go from date to instant return d != null ? dateToInstant.convert(d, target) : null; }
public Converter createConverter(Class<?> source, Class<?> target, Hints hints) {
if (Instant.class.isAssignableFrom(target)) {
if (Date.class.isAssignableFrom(source))
{ return dateToInstant; }
{ return stringToInstant; }
return null;
geoserver/src/extension/wps/wps-core/src/main/java/org/geoserver/wps/executor/ProcessStatusTracker.java
public void cleanExpiredStatuses(long expirationThreshold)
{ Date date = new Date(expirationThreshold); Not completionTimenotNull = FF.not(FF.isNull(FF.property(“completionTime”))); Filter completionTimeExpired = FF.before(FF.property(“completionTime”), FF.literal(date)); Filter completionTimeFilter = FF.and(completionTimenotNull, completionTimeExpired); Not lastUpdatedNotNull = FF.not(FF.isNull(FF.property(“lastUpdated”))); Filter lastUpdatedExpired = FF.before(FF.property(“lastUpdated”), FF.literal(date)); Filter lastUpdatedFilter = FF.and(lastUpdatedNotNull, lastUpdatedExpired); And filter = FF.and(completionTimeFilter, lastUpdatedFilter); store.remove(filter); }
geotools/modules/library/main/src/main/java/org/geotools/filter/FilterFactoryImpl.java
public Literal literal(Object obj) {
try
{ return new LiteralExpressionImpl(obj); }
catch (IllegalFilterException e)
{ new IllegalArgumentException().initCause(e); }
return null;
geotools/modules/library/main/src/main/java/org/geotools/filter/LiteralExpressionImpl.java
public LiteralExpressionImpl(Object literal)
throws IllegalFilterException
{ this.setValue(literal); }
public final void setValue(Object literal)
{ this.literal = literal; }
public Object getValue()
{ return literal; }
{ return literal == null ? “NULL” : literal.toString(); }
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.773.2#100032-sha1:6cd161b)
Atlassian logo
