Steve Ikeoka created an issue |
Issue Type: |
Affects Versions: |
2.10.1 |
Assignee: |
Unassigned |
Components: |
JDBCConfig |
Created: |
01/Mar/17 12:08 AM |
Priority: |
Reporter: |
A NullPointerException is thrown during the JDBC Configuration import if there is a layer group that contains at least one layer group and at least one layer and any of the layers are after a layer group. Attempting to create a layer group like this while running JDBC Configuration will also throw an NPE. Editing an existing layer group seems like it may work fine. will throw NPE: will throw NPE: will not throw NPE: When adding a Layer Group in the GUI, a Layer with the Default Style box checked can be used in place of a Layer Group to trigger the NPE. I haven’t tested whether the equivalent XML configuration also throws the NPE during the import. The NPE occurs while adding the styles.id property for the layer group. |
This message was sent by Atlassian JIRA (v1000.789.1#100032-sha1:3f94b35) |
