Richard Duivenvoorde created an issue |
On WIndows, Create Store interface creates invalid URL/path: unable to create store |
Issue Type: |
Affects Versions: |
2.10.2 |
Assignee: |
Unassigned |
Attachments: |
windowserror2.jpg, windowserror.jpg |
Components: |
Configuration, image mosaic, UI, Wicket UI |
Created: |
02/Mar/17 10:23 AM |
Environment: |
WIndows binary and war installs. Tested on both WindowsServer2008 and a recent 64bits WIndows10 Desktop |
Priority: |
Reporter: |
On Windows using Geoserver 2.10 admin webinterface, try to create a Image Mosaic store by using the browse button and browse to whatever directory outside the GEOSERVER_DATA_DIR folder (be it on c: or d: or e Could not list layers for this store, an error occurred retrieving them. Failed to create reader from file://D:\data and hints is null Note that in 2.8 the same url’s/paths just work: Funny thing is (see windowserror2.jpg) that browsing for a Shapefile store you will see the same funny file-URL’s: Maybe it has something to do with the types of datastore (which handle the URL’s?) or maybe it has something to do that for a shapefile you point to a FILE and for a MosaicStore you point to a DIRECTORY? |
This message was sent by Atlassian JIRA (v1000.789.2#100032-sha1:1297bd3) |
