[Geoserver-devel] [JIRA] (GEOS-8013) GetFeature GET request with 3d bbox fails to parse
Andrea Aime [Administrator] created an issue
GeoServer / BugGEOS-8013
Issue Type:
BugBug
Assignee:
Unassigned
Created:
02/Mar/17 10:28 AM
Priority:
MediumMedium
Reporter:
When using the following configuration, a POST requests seems to result in Geoserver loading all features from database and performing the BBOX filter internally.
Environment:
  • Postgresql: “PostgreSQL 9.2.4, compiled by Visual C++ build 1600, 64-bit”
  • Postgis: “POSTGIS=“2.0.3 r11132” GEOS=“3.3.8-CAPI-1.7.8” PROJ=“Rel. 4.8.0, 6 March 2012” GDAL=“GDAL 1.9.2, released 2012/10/08” LIBXML=“2.7.8” LIBJSON=“UNKNOWN” RASTER”
  • Geoserver 2.9.1 and 2.10.1
  • JVM 1.8.0_112
Table creation:
CREATE TABLE table_wmk_lijn_2016
  stdx double precision,
  stdy double precision,
  stdz double precision,
  meas_info text,
  quality double precision,
  fid integer NOT NULL DEFAULT nextval('table_wmk_lijn_2016_seq'::regclass),
  objecttype text NOT NULL,
  date_recorded timestamp with time zone,
  date_modified timestamp with time zone,
  username text,
  comment_cm text,
  height text,
  the_geom geometry(LineStringZ,7415),
  objectstatus text,
  CONSTRAINT table_wmk_lijn_2016_pkey PRIMARY KEY (fid),
  CONSTRAINT enforce_dims_geom CHECK (st_ndims(the_geom) = 3),
  CONSTRAINT enforce_geotype_geom CHECK (geometrytype(the_geom) = 'LINESTRING'::text OR the_geom IS NULL),
  CONSTRAINT enforce_srid_geom CHECK (st_srid(the_geom) = 7415)
A GET request results in the following error:
http://myserver.com:8080/geoserver/ows?SERVICE=WFS&VERSION=1.1.0&REQUEST=GetFeature&SRSNAME=EPSG:7415&TYPENAME=inl:table_wmk_lijn_2016&BBOX=86620.02749999995,437105.71499999886,86787.92249999997,437198.7449999985,EPSG:7415
<ows:ExceptionReport xmlns:xs="http://www.w3.org/2001/XMLSchema" xmlns:ows="http://www.opengis.net/ows" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" version="1.0.0" xsi:schemaLocation="http://www.opengis.net/ows http://geoserver-c.cyclomedia.com:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd">
  <ows:Exception exceptionCode="NoApplicableCode">
    <ows:ExceptionText>org.opengis.geometry.MismatchedDimensionException: Argument "Amersfoort / RD New + NAP height" has 3 dimensions, while 2 was expected.
Argument "Amersfoort / RD New + NAP height" has 3 dimensions, while 2 was expected.</ows:ExceptionText>
  </ows:Exception>
</ows:ExceptionReport>
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.789.2#100032-sha1:1297bd3)
Atlassian logo
