[Geoserver-devel] [JIRA] (GEOS-8019) Advanced Reprojection Handling may generate huge width*heigh requests at native resolution
Daniele Romagnoli created an issue
GeoServer / BugGEOS-8019
Issue Type:
BugBug
Affects Versions:
2.10.2
Assignee:
Andrea Aime [Administrator]
sample.zip
Created:
06/Mar/17 1:02 PM
Priority:
MediumMedium
Reporter:
Daniele Romagnoli
A fake imagePyramid sample data is attached.
It contains
  • a level 0 made of 2 corner granules R0001C0001 and R0134C0116
  • a level 1 made of 1 granule
    Data is in EPSG:3003
A reprojecting request is sent in EPSG:900913 covering a wide bbox to be put into a 256x256 tile.
http://localhost:8080/geoserver/wms?SERVICE=WMS&FORMAT=image%2Fpng8&TRANSPARENT=TRUE&TILED=true&LAYERS=sample:sample&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&VERSION=1.1.1&REQUEST=GetMap&SRS=EPSG%3A900913&BBOX=-15028131.255,-5009377.085,-10018754.17,0&WIDTH=256&HEIGHT=256
When Advanced Projection Handling and Continuous Map Wrapping are turned off, the result is immediately produced.
When they are turned on, the requests turns into a GridCoverage read operation which use a similar GridGeometry, asking for a huge WIDTH * HEIGHT image, using native resolution:
GridGeometry2D[GridEnvelope2D[-10…679999653, -10…675520900], PARAM_MT[“Affine”,
PARAMETER[“num_row”, 3],
PARAMETER[“num_col”, 3],
PARAMETER[“elt_0_0”, 0.20000000010750243],
PARAMETER[“elt_0_2”, -113329181.65691483],
PARAMETER[“elt_1_1”, -0.1999999999694039],
PARAMETER[“elt_1_2”, 17880331.806959655]]]
This will take forever when dealing with a real pyramid made of thousand of files at level 0 (and may throw OOM error when not using deferred execution)
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.789.5#100032-sha1:b95a5c1)
Atlassian logo
