[Geoserver-devel] [JIRA] (GEOS-8026) JMS community module wrongly listen on service post change event
Nuno Oliveira created an issue
GeoServer / BugGEOS-8026
Issue Type:
BugBug
Assignee:
Nuno Oliveira
Created:
09/Mar/17 11:19 PM
Priority:
MediumMedium
Reporter:
Nuno Oliveira
JMS community module service events handler wrongly listen on service post modify event:
https://github.com/geoserver/geoserver/blob/master/src/community/jms-cluster/jms-geoserver/src/main/java/org/geoserver/cluster/server/JMSConfigurationListener.java#L126-L131
At some point the JMS handler will try to create a new service for the post modified event and will fail:
https://github.com/geoserver/geoserver/blob/master/src/community/jms-cluster/jms-geoserver/src/main/java/org/geoserver/cluster/impl/handlers/configuration/JMSServiceHandler.java#L59-L66
JMD plugins should ignore service post modify events and only use service chnaged events to manage new and modified services.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.815.1#100035-sha1:b7e3b95)
Atlassian logo
