[Geoserver-devel] [JIRA] (GEOS-8057) Requesting images stored in EPSG:4326 in EPSG:3857 pixelates the image
Richard Cho created an issue
GeoServer / BugGEOS-8057
Issue Type:
BugBug
Affects Versions:
2.10.1
Assignee:
Unassigned
Created:
29/Mar/17 11:46 PM
Environment:
Data stored in EPSG:4326 in PostGIS datastore
GeoServer version 2.10.1
GeoTools version 16.1
Priority:
HighHigh
Reporter:
Richard Cho
I have images that cross the dateline, so I store the data in EPSG:4326 in my datastore.
Under my GeoServer WMS settings I have Enable advanced projection handling and Enable continuous map wrapping turned on.
When I request the imagery in EPSG:4326, the stored projection, images look good. But when I request the imagery in EPSG:3857, the images all look pixelated.
This happens to all images, even the ones that do not cross the dateline.
To summarize:
Problem is that requesting images stored in EPSG:4326 with EPSG:3857 projection with advanced projection handling ruins the image resolution.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.844.2#100035-sha1:71171a4)
Atlassian logo
