[Geoserver-devel] [JIRA] (GEOS-8075) When i use WMTS services, it often called 400 error
Huyiwei created an issue
GeoServer / BugGEOS-8075
When i use WMTS services,it often called 400 error
Issue Type:
BugBug
Affects Versions:
2.10.2
Assignee:
Unassigned
Created:
07/Apr/17 9:45 AM
Priority:
HighHigh
Reporter:
Huyiwei
Here is the thing,i use the openlayer.js to call geoserver WMTS service. The map is showed,but at the console,there are a dozen of error. When i used the other WMTS service it’s all right.Then I look up the geoserver document, it is less information about the WMTS service.I was already use the Tile Layer’s seed to construct the tile. And the console error is Row or Column is out of range.I don’t know how to do.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.885.0#100040-sha1:032ab14)
Atlassian logo
