[Geoserver-devel] [JIRA] (GEOS-8078) JMS community module configuration WEB page throws an exception when accesing it
Nuno Oliveira created an issue
GeoServer / BugGEOS-8078
Issue Type:
BugBug
Assignee:
Unassigned
Components:
Community modules
Created:
07/Apr/17 6:09 PM
Priority:
MediumMedium
Reporter:
Nuno Oliveira
To reproduce this issue just try to access the JMS cluster plugin configuration page, the following exception will be throw (full stack trace attached):
Expected close tag for '<button type="submit" wicket:id="connectionB">' Possible attempt to embed component(s) '<wicket:message key="connectionB">' in the body of this component which discards its body MarkupStream: [markup = file:/home/nuno/github/geoserver/src/community/jms-cluster/jms-geoserver/target/classes/org/geoserver/cluster/impl/web/ClusterPage.html <button type="submit" wicket:id="connectionB"> <wicket:message key="connectionB">connectionB</wicket:message> </button>, index = 2, current = '<wicket:message key="connectionB">' (line 0, column 0)] at org.apache.wicket.markup.MarkupStream.throwMarkupException(MarkupStream.java:526)
This may be a consequence of the upgrade from Wicket 7.1.0 to Wicket 7.2.0.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.885.0#100040-sha1:032ab14)
Atlassian logo
