[Geoserver-devel] [JIRA] (GEOS-8095) Backup and restore should backup none core elements
Ami Rahav created an issue
GeoServer / ImprovementGEOS-8095
Issue Type:
ImprovementImprovement
Assignee:
Unassigned
Created:
16/Apr/17 7:50 PM
Priority:
MediumMedium
Reporter:
Ami Rahav
Currently backup and restore doesn’t backup the configuration of all extensions.
As an example, with the Geogig extension, only the Geoserver stores are backed up, however the Geogig repositories configuration in Geoserver is not backed up, which means that REST HTTP calls need to be made to backup and restore Geoserver’s configuration.
If possible, make sure that the configuration of all extensions is backed up and restorable.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.892.2#100040-sha1:0bee0d5)
Atlassian logo
