Steven D. Lander created an issue |
Cannot build project using org.geoserver:gs-main:2.10.0 with Gradle |
Issue Type: |
Affects Versions: |
2.10.0 |
Assignee: |
Unassigned |
Components: |
Global |
Created: |
19/Apr/17 4:03 PM |
Environment: |
Linux running Gradle 3.1 |
Priority: |
Reporter: |
See Github issue logged under the Gradle project: Gradle will not satisfy the dependency for commons-beanutils-1.9.2-noclassprop.jar in the https://repo.boundlessgeo.com/main repository for some reason. I wanted to bring this to the team’s attention in case there is anything you can do. This issue currently blocks the building of my project, and the only workaround is to run on a container with the mavenLocal() repo containing noclassprop from the buildout of another project. The other (potential, unconfirmed) workaround is to switch to maven completely from gradle. |
This message was sent by Atlassian JIRA (v1000.892.2#100040-sha1:0bee0d5) |
