[Geoserver-devel] [JIRA] (GEOS-8098) Clarify Service Error Settings admin UI + docs
Devon Tucker created an issue
GeoServer / BugGEOS-8098
Issue Type:
BugBug
Assignee:
Unassigned
Created:
19/Apr/17 8:09 PM
Priority:
LowLow
Reporter:
Devon Tucker
The “Service Error Settings” section of the Global Settings and its associated docs are a bit confusing for users, and the documentation has some errors (for example, it claims both options are default).
IMO we should:
  • Clarify the UI screen to make clear that the option only applies to capabilities doc generation.
  • Update the doc to fix inconsistencies
  • Fix the formatting on that section, as it’s a little off (parts are bolded, weirdly aligned, see screenshot)
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.892.2#100040-sha1:0bee0d5)
Atlassian logo
