Nathan created an issue |
Issue Type: |
Affects Versions: |
2.11.0 |
Assignee: |
Unassigned |
Components: |
ArcSDE, Control-flow |
Created: |
25/Apr/17 10:23 AM |
Priority: |
Reporter: |
Hello all Not sure if it is a bug or a misconfiguration. There the story : We use Geoserver and we are 4 to work with the geoserver and QGIS solution. We use a file as a container of shapefiles and we all have to work on the sames shapefiles at the same time. But we encounter some issues that we don’t understand : When we modify the geometry or, the attributes of multiple entities in the shapefiles, if we dont save the shapefile between EVERY MODIFICATION, the attributes or the geometry is cloned and all the objects that we have modified have now the same geometry or the same attributes (the same as the last modified). Can somebody explain me why and what we have to fix it. |
This message was sent by Atlassian JIRA (v1000.910.0#100040-sha1:0b083fc) |
