[Geoserver-devel] [JIRA] (GEOS-8123) GWC caches stale response encoders
Ben Caradoc-Davies [Administrator] created an issue
GeoServer / BugGEOS-8123
Issue Type:
BugBug
Affects Versions:
2.12-beta
Assignee:
Components:
GWC
Created:
03/May/17 5:10 AM
Priority:
MediumMedium
Reporter:
GWC.cachedTileEncoders should not be static because it then references stale beans when a new application context and GWC singleton are created. Because it should usually be recreated whenever the GWC singleton is recreated, a member variable seems a more robust solution.
This defect caused the failures noted after GEOS-8122 In Progress was fixed.
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.929.1#100040-sha1:44337ab)
Atlassian logo
