[Geoserver-devel] [JIRA] (GEOS-8126) Error when create datastore using cURL Rest API
Jinzhou Zhang created an issue
GeoServer / BugGEOS-8126
Issue Type:
BugBug
Affects Versions:
2.9.1
Assignee:
Unassigned
Components:
REST
Created:
05/May/17 1:52 AM
Environment:
Ubuntu 16.04
Geoserver 2.9.1
Using node-request make cURL call
Priority:
MediumMedium
Reporter:
Jinzhou Zhang
I am using cURL API to do operations over my geoserver. Now I am stuck on creating data store.
From cURL API’s official tutorial, I should create a data store using this uri:
/workspaces/<ws>/datastores/<ds>/[file|url|external][.<extension>]
I did it and a data store was posted on my geoserver. However, the data store is different from data stores I created manually. Here are the differences:
  1. the data store doesn’t have a default feature type which can be published as a layer
  2. when I click it in datastore tag, it doesn’t pop up a screen where I can edit it. Instead, it gives me this error page.
Do you know how can I resolve the issue? What I need is a regular data store which I can use to publish a layer.
Thanks and Regards,
Jinzhou Zhang
Add Comment
Add Comment
This message was sent by Atlassian JIRA (v1000.929.2#100040-sha1:94c1764)
Atlassian logo
